What did your compression test read?
Discussion in 'General Tech and Maintenance' started by phyregod, Jul 23, 2005.
  1. phyregod
    phyregod !!YTINASNI
    Central Texas
    I'm about to compression test my new motor.
    I'm curious what it is going to read, I had the head decked "as much as possible".. and polished combustion chambers with deshrouded valves. Otherwise, it is a stock B18A1 as far as compression is concerned. What did yours read?
    I'll post mine when I'm done today.
  2. B16CRX
    B16CRX Senior Member
    Greenville, SC
    my stock b16A scored 235 all the way accross. 10.2:1 CR
  3. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    ^^Woah, thats way too high. Mine was 175-180psi all across...and from what I hear, that is pretty normal for b-series honda engines.
  4. GSRCRXsi
    MD
    my gsr (10:1) had like 230-240 across.
  5. jamesA
    whoa... aren't they supposed to be around 210?
  6. BigJ
    My prelude was 200 across.
  7. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    d15: 210-200 and then 160 on cylinder 3 :(
  8. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    cool. I deshrouded and polished my chambers as well, but left the stock deck height, and opted for some custom 11.5:1 CP slugs. Eager to see your results.
  9. 97CTR
    97CTR Senior Member
    250 all the way across
    and having high compression numbers from a test is not bad, also it may not have been done 100% correctly.
  10. noobvang
    noobvang Senior Member
    Twincities, MN
    Got 270 all across with a 12:1 CR (Redecked block of .10 and milled head off .15)
  11. phunky.buddha
    Dallas / Fort Worth, TX
    Got:
    1 267
    2 276
    3 265
    4 269
    on 12.8:1 compression, only 4 pumps on gauge- any more and it would top out the compression tester.
  12. noobvang
    Twincities, MN
  13. phunky.buddha
    Thanks! If I had let it keep pumping to where it stopped moving the needle, I would have needed a 400psi gauge... it would have topped out somewhere in the 350 range probably.
  14. B16CRX
    Greenville, SC
    My compression test was done correctly. Its not easy to screw that up. lol. I always heard 230's was normal for a b16.
  15. D See 2
    D See 2 Senior Member
    Baltimore, MD
    Manual says compression tests should be done when the engine is at operating temp. I'll bet half of you did it while cold. Which is why everyone's readings seem high...
    This is straight from the service manual VTEC Supplement OBD0 B16a 10.2:1
    Notice the standards... 185 psi...
  16. MikeBergy
    Central Coast, CALI
    LOL I like #7.
    "when pressure is high, inspect the following item: accumulated carbon on piston and cylinder head"
    JDM compression raise, yo!! :)
  17. 97CTR
    97CTR Senior Member
    that guide sucks. Doesn't tell you how many times to crank the engine over, doesn't tell you to depress the gas pedal while doing the test either. And I remove my FI fuse so I am not still spraying gas into my cylinders also.
  18. B16CRX
    Greenville, SC
    same here, only I just flip my fuel pump kill switch. and crank until teh needle stops. (with accelerator floored of course)
  19. Som1Dies2Nite
    Som1Dies2Nite Member
    My brothers D15/Z6 head is getting 220, 185, 155, 220.
  20. n20hatch
    n20hatch Member
    Oregon
    JDM obd1 b16a
    cyl 1 180
    cyl 2 80
    cyl 3 125
    cyl 4 160
    Woot woot, headgasket and rings on cyl 2 lol
