What distributor and ECU?????
Hondatuner88
Hey guys...some help needed here...Im looking into buying at b16a2 longblock for my 94 hatch...I have everything else already (trans, axles,harness,mounts,shift linkage)...Just need to know what ECU and what distributor I can use...Anything off another honda/acura?? Thanks guys!!
ecu, p30 or chipped p28 (p30 is the stock ecu)
dizzy, i believe b-series all work together, correct me if i'm wrong
you can use a p28 ecu or a p30 and i recommend any 92-95 DOHC VTEC (del sol or integra)
distributor. If not you can use a regular b18 non vtec distributor but you will have to cut
off one of the lobes on the distributor to make it fit with the vtec spool assy.
(if you are looking at the distributor mounted on the motor from the passenger side of the car, the lobe to
cut would be the bottom right one (or the one thats closest to the front of the car.))
