what do i have to do to spray my civic
Discussion in 'Forced Induction' started by stepley4, Feb 17, 2009.
  1. stepley4
    stepley4 New Member
    psl
    i have a 1995 stock civic what will i need to replace. to spray it?
  2. MthaFuknGreen
    Lodi, CA
    sand it down and prime it.
  3. PvcWalden
    PvcWalden New Member
    Indianapolis, IN
    Spray is like a girl with an std, you want to hit it but youre scared of what will happen.
  4. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    Check the compression first thing. Then stick with a 50shot at first and see how it holds up. A Wideband wouldn't be a bad investment if you plan on running it a lot. It will tell you if you need custom tuning at least.
    My honest opinion tho, since Ive done the Juice route a couple times. It's fun, YES. BUT, you have to fill that bottle to have fun and it can cost $50-$80 a fill!!! Save a few more bucks and build a turbo kit, or buy a used one. Its readily available fun once it's on!
  5. hondamanshawn
    hondamanshawn New Member
    Lebanon, P.A.
    If you are looking to just strap on a kit and call it a day, I would go with a wet kit for shure! It's gonna be alot safer and make shure you retard you'r timing when you wanna spray, you can put two marks on you'r dizzy so you can just slide it where you want it if you'r spayin or not.
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    you should do nitrated pistons so it doesnt eat the tops of them but thats on you..
  7. disableddan
    disableddan Crazy Insane
    Edmonton Canada, Eh?
    Ya there are some "diy" heat treatments available, I have an old issue of chevy high performance where tey tested the shit to destruction with a blow torch... The coating actually holds out longer than the piston- the piston begins to melt even though the treatment hadn't yet failed :D Plus it probably ups your compression a hair having that layer on top of the piston...
