what do i need for this swap.
Discussion in 'HYBRID -> EG-EK / DC' started by hondahead505, Apr 24, 2006.
  1. hondahead505
    hondahead505 Junior Member
    Whats up everyone at hondaswap.com well any ways I need help for this swap I have a 94 civic dx and my brother gave me a b16a motor :mrgreen: from an ef because he totaled his car, anyways back to my question what do i need to do this swap, can i use the 90-93 integra shift linkages and what kind of motor mounts do i need, I dont have much cash for hasport mounts so is there a cheaper way to do this. Please let me know guys
  2. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    well i have found out the hard way that the 90-93 linkage barely goes in gear so no it wont work. read up a little more there is plenty of info available on here.
  3. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    If the engine came out of an EF, it's probably got a cable tranny... If so, you're gonna need one of those Hasport hydro-to-cable conversion things. You're gonna need 94-01 Integra motor mounts as well as the shift linkage. Also you're gonna need an OBD-1 ecu or a jumper harness if to match the OBD of the ecu that was in the EF. You can find all of this info if you do a search...
