what do i need to add bisc brakes
Discussion in 'Wheels / Suspension / Tires / Brakes' started by mygsr, Jun 7, 2005.
  1. mygsr
    mygsr Member
    LOS ANGELES
    i have a 94 honda civic with rear drum brakes and i been wanting to add rear disc brake of a what integra could i get the disc brakes what else do i need off the integra
    e-brake line
    disc brakes
    i think also the proportion valve :ph34r:
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    search bub
    this has been covered....
    if you don;t find a write up on here try google.com
    i'm not trying to be a dick, but i don;t know the parts off hand
  3. formby
    formby learning in progress
  4. pissedoffsol
    eg civic si
    eh del sol si
    eg2 del sol vtec
    em1 civic si
    dc gsr
    trailing arms, upper & lower lcas (em1 will need to be swapped for one of the others), spindle, hub, rotor, caliper, e-brake cables.
    etc...
    91 civic ex 4-door master cyl (15/16th, bolts to stock booster)
    90-93 teg (Da) non-abs 4040 ppv
