what do I need to do about wiring harness
Discussion in 'HYBRID -> ED-EF / DA' started by shadowrex, Aug 11, 2005.
  1. shadowrex
    shadowrex Junior Member
    I started an b18a engine swap out of a 91 integra into rex. I'm trying to find the b-series engine mounts for cheap and a conversion harness if necessary if any one has any ideas of what else I need to do or any of you honda gods can help me figure this mess out let me know ASAP! :worthy:
  2. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    If the rex is an HF or Si its plug and play. Just remove the old engine, install the new engine using mounts (http://hasport.com, cheap mounts break, do it right the 1st time), plug in the sensors, plug in the integra ECU, and drive away.
    If you have a DX, you have to do the DPFI to MPFI conversion, which pretty much entails splicing in the wiring for 2 more injectors. There should be a write up on it somewhere.
  3. DirtyRice
    DirtyRice Junior Member
    go on ebay and type in "civic mount kit". you can find 1 on there for around 150 bux. use your stock harness and just mod it according to the application.
    Be good
    -DirtyRice-
    !!!Got to my website and get my newest album free!!!
    [​IMG] [​IMG]
