what do i need?
seeking land
what do i need to fit a GSR into my 97 civic ex
would civic si mounts work?
would the ex shift linkge do?
any help at all will be greatly appreciated thanks
99-00 Civic Si mounts will work. You can use Integra mounts, and just use a 99/00 si rear mount. You will need a B-series shift linkage, so no, the ex one will not work unless you modify it.
All the info you need is in the reference section. Don't expect to be constantly spoon fed information that is easily available by searching.
