What Do You Think Its Worth
Discussion in 'Parts: For Sale/Trade/Wanted' started by hybrid hatch, Apr 25, 2003.
  1. hybrid hatch
    hybrid hatch Junior Member
    Ok Just shooting this up to see what i might get for this car if i sold it.
    91 Civic Hatch DX
    Car is black shiny been repainted and waxed weekly
    carbon fiber hood
    Rota slipstreams in black 15 in w/ 205/50/15 bfg drag radials on fronts and 195/50/15 kumho's on the back
    2 Corbeau Forza racing seats in red w/ black harness to match
    Si guage cluster
    HP racing coilovers
    Koni Yellows for shocks
    DC sports lower rear tie bar polished
    Upper generic strut bar polished
    Motor includes the following
    LSvtec
    81.5mm bore
    Endyn rollerwave pistons 12.5:1 no problem on pump gas
    Stock rods balanced
    Stock crank micropolished and balanced to 10k
    ARP rod bolts
    ARP head studs
    Cometic head gasket w/ .006 higher fire ring to have o-ring effect
    all new seals water pump oil pan ect for entire motor
    AEM cold air intake
    Skunk2 intake manifold
    Skunk2 valve springs
    Skunk2 retainers
    Skunk Stage 2 cams
    Typer valves
    Competion 3angle valve job
    Ported JDM itr header w/ 2.5 collector
    Full custom 2.5in exhaust w/ tenabe muffler
    JUN cam gears
    Type r valve cover
    carbon fiber spark plug cover
    MSD blaster2 coil
    Transmission is a Y1 w/ new sncroys and sliders doesnt grind at all w/ phanton grip lsd unit
    Car also has vafc
    KVR cross drilled rotors and metal matrix pads up front as well
    Car is in excellent shape nothing wrong w/it this car runs high 12's untuned have the timeslips to prove it. W/ tuning and upgraded throttle body and light flywheel car will run mid 12's w/ serious making this car light w/ stripping and fiberglass body parts this can be and 11sec car i believe
    just courious on what you think its worth
  2. pissedoffsol
    waxed weekly???
    does the thing have any paint left on it???
    other than that, id say 4-6 grand.... depending on how bad you want to sell it
  3. Dancomer
    Dancomer Senior Member
    Gurnee, IL
    i say 3800 due to the paint that has been replaced with dyed wax....j/k it sounds like a nice all mtor setup but i still like my low 13 sec turbo D15B vtec.
  4. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    nice setup, but they are right, your only supposed to wax your car when it NEEDS it, your supposed to use a POLISH weekly.
  5. hybrid hatch
    dude ive been detailing since i was 15 i know how to clean cars if you strip the wax like your supposed to you can use a cleaner wax then a glaze and then a carnuba top coat when you stip it w/ special soap you dont have anything protecting paint and needs to be done all over agian
  6. Dancomer
    Gurnee, IL
    this is what i heard....blah blah blah blah blah....oh well i now know that i know absolutely nothing about detailing...although i did work at Honda.....oh well that is my 2 cents
  7. mattcalica
    mattcalica Senior Member
    sounds like a really nice setup...but everybody is right, you will probably only get around 4 g's, so by selling it you will be taking a big loss....most people dont want a car with that much work put into it. Its like driving somebodys elses trophy. You should keep that car, save up some cash and buy a pos daily driver and turn the hatch into a full gutted dragster...
  8. BigJ
    yeah if I was looking for a 4th gen, I would probably give you 4g's for it. Really you are better off taking out the swap and selling for like 4k to someone, and putting in a stocker motor and selling for another 2500.
  9. liquid00meth
    Laconia, NH
    Thanks chief I work in a detail shop. And doing that every week is just a plain waste of time.
  10. hybrid hatch
    to each his own i have a daily beater right now but you wont find an lsvtec swap w/ this much work done to it for under 3500 everything is like brand new in the motor plus the car is clean i will have to post pics up. I have debated on making a full drag car but i want to see about maybe competeing in sport fwd class and w/ this setup i need more stuff to do id rather go turbo in another chassis but thats another topic all together all im saying is you can barely buy a swapped crx or hatch w/ b16 for that much no offense but w/ mounts plus what swap cost to get installed and mounts youhave close to 2300 for it in the car plus the cost of the car which is clean as hell. Will someone post some pics for me if i send them to you
