What do you use?
Discussion in 'General Tech and Maintenance' started by EGDriver93, Sep 22, 2009.
  1. EGDriver93
    EGDriver93 New Member
    Thought it would benefit people to see what types of gas people use? Brands? Gas Mileage? Just something to question since were always trying to save gas. One reason I bought the Honda.
    1993 EG Si
    51MPG @70mph- Freeway
    I use Shell Premium, sometimes Chevron. Every other fill, I'll put octane booster in it to keep it clean.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    damn even the hf back in the day barely got those numbers
  3. EGDriver93
    Yeah, I admit. I had to do the calculations a few times. But on my road trip, that's what it came out to. haha Has to be a combo of the new spark plugs/ wires, new fuel filter, aerodynamics. In the city its horrible, Who knew?
  4. EGDriver93
    So according to someone who has corrected me on how large the gas tank is on my car (11.8), I only get 47MPG. Damn, thought I could break the 50 mark.
  5. AHHVTEC
    Alabama
    if its accurate 47mpg is still awesome for that car
  6. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    Fill up just until it auto stops itself. Drive until you need it filled up and again fill it just until it stops pumping. Divide your trip by how much you put in. Just going by what the cars tank holds only works if you are entirely empty. You most likely used less than 11.8 gallons and maybe hit closer to the 50mpg mark.
  7. reikoshea
    Dallas, TX
    Gasoline Fuels | US EPA
    If you take the time to read a lot of the regulations in there, you'll notice that the additives and quality of fuel put in the tanks at your local gas station are VERY strictly regulated. So much so that you're only going to notice about 1% difference between fuel from different companies. The commercials the shell and the other oil companies put out about their detergents being better for your engine is kind of a half truth. Yes, the detergent they add can benefit your engine. Is it better than the other guys? Maybe yes, but by a margin so low that it really doesn't matter. Those comparisons they do with engine components are usually vs detergent free gasoline. That's why the results appear so dramatic.
    Please note that the octane booster doesn't hurt either and can actually be good for helping with the moisture that can build up in your gas tank, especially if you have an older car. Just to clarify that the octane booster wont get rid of the moisture, but it lessens the effect on the internals of your engine.
  8. EGDriver93
    See this is info. people can benefit from. Thanks guys.
    Yeah I had an idea that the question, "Is this fuel better than the other guys' across town?" is really just preference to me.
  9. Magana559
    Magana559 The Warden
    fresno Ca
    same here, shell V-power 30-36 mpg @ 70-80 in a 95 teggy with b16/LS tranny slight engine mods and tuned with 310cc injectors.
  10. EGDriver93
    You use 310cc injectors? I was wondering what a nice step up from stock would be without going insane with 600cc injectors. Have they worked alright for you? Do you have any other fuel related mods?
  11. 78civic
    78civic Junior Member
    NW MS, Y'all
    Here in Memphis,(TN) they don't regulate the fuels whereas Mississippi does.
    Any tanker can 'pull up' at Presidents Island (port) and pump to whomever..
    Another thing, I've seen tons of 02 sensors go bad around here because of 'them' selling crap gas for premium price. In addition, Octane booster usually leaves a rust colored build-up on the electrode, which if it builds up enough along with other contaminants can short it out.
    Anywho, I'm getting 38@70 w/city mph in a pretty much stock 90 civ. I wonder how much it will go down when I do the TPI conversion??
    A local friend was getting 61mpg with air on in his 90 crx HF (for sale too!!)
    E
  12. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    i use whatever 93 octane is cheapest at the time. as far as gas mileage, i dont really care. its not good though, less than 20 around town with the built and blown b20vtec.
  13. Ronny Cage
    Ronny Cage DaughterTestedMomApproved
    south jersey
    in nj... 93 octane 2001 honda s2000 everything done minus some boost lol... I average 18mpg but I normally drive 5-15 miles a day and its all stop go and curvy roads ;)
  14. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    93, mostly from BP since it's in my neighborhood.
    C350 gets around 24 on avg
    350Z gets maybe 25-30 MPG if I'm already up to speed just rolling.
    I figure around 18-22 if there's some stop and goes.
    Around 5mpg maybe less if under load. A short trip to a local place can easily eat a 1/4 tank of gas.
  15. jeffie7
    Maryland
    Try having 600cc injectors x 6 :(
  16. EGDriver93
    Yeah that sucks...literally. We don't have 93 octane here in Oregon. We have up to 91, but some people say they have found 93, but its really crap gas. At my local Chevron, you can buy race gas in 10 gallon tanks. haha Could not believe it.
  17. serrilion
    serrilion In my own little world! VIP
    Vermont
    I run 93 pump gas 4.5 Gallons and put in 4.5 of 102... I see about 46mph with my D15B at 75 mph on the freeway... lmao...with Shell 87 I get 438 miles to a tank... tanks only 9.002 gallons
  18. 78civic
    NW MS, Y'all
    I remember reading a story in some car mag that stated the higher octane makes the flame burn slower. I wonder if that was correct?
    Kinda make sense in a way that the crank pin has already past TDC and since it's still burning, it's still giving force to the rod on the way down the other side.
    Hhmm. E
  19. reikoshea
    Dallas, TX
    it has a higher flash point meaning it takes more compression and a hotter spark to make it burn.
    In a high compression engine 87 octane can burn just with the compression and the heat of the block.
    The flame may burn slower, but that is likely a by product of the fact that it takes more energy to burn.
  20. 99sidude
    Ohio
    I got 32-33 highway in my jrsc gsr hatch running 93 octane BP gas. Around town I was boost happy and only got about 15. My current type r hatch only gets about 26mpg combined running 93 octane BP.
