what does everyone think about this header
Discussion in 'Engine Building' started by b18c1vic, Mar 5, 2007.
  1. b18c1vic
    b18c1vic Junior Member
  2. 97CTR
    97CTR Senior Member
    Did you happen to read the whole listing? The bolt holes on the header flange don't line up with the head. They say to fix them yourself and that its simple. If it was so easy, why wouldn't they take the time to fix the holes and then not even have to put that in their listing? Probably made with cheap tubing and prone to cracking and coming apart at the welds. You get what you pay for in this case.
  3. eg6sir
    steer clear of that... best header on the market my ass.. why is it cheaper than a DC then??
  4. 97CTR
    97CTR Senior Member
    Once you adjust the bolt holes you will also run the chance of the header ports not lining up well with your exhaust ports of the head.
  5. b18c1vic
    Thanks a lot for the input, I think I will go with a megan. I haven't heard anything bad about those headers and they're considerably cheaper than a jdm dc.
