Originally posted by saturn_boy96@Sep 29 2003, 07:33 PM
since your going turbo your hp gains are going to be to large for a fmu to be sufficient, so use the afc as your fuel management and if you use the afc hack it bypasses the map sensor, and also allows you to boost more than 7psi.
im not really sure what youre saying here, but just fyi-
the afc hack does not bypass the map sensor. it relies solely on that to keep your engine from blowing up. if you DO use a missing link to bypass the map sensor..well, i hope you have a spare motor in teh garage
and also im not sure where you got the "7 psi" figure...care to elaborate?
