guess you didnt read my post.. heh
the 2 wires for vtec and one for the new 4wire o2 is in your chassis harness.. if you look at your engine harness on the leftside when facing the car.. look at the biggest plug.. one side has all the wires.. (chassis side) and the other plug (engine side) is missing 3.. just take those three little caps out put in some new pins..
look at the chassis side to get the colors i'm talking about.. but here ya go..
orn/wht - vtec solenoid
orn/blu - vtec pressure switch
orn/blk - 4 wire o2 sensor.. usually blk/wht wire
that will hookup one wire of your 4wire o2.. and vtec (assuming you ground the black wire on the pressure switch..) this way you're not running stuff into the firewall or anything and the harness will just disconnect if you ever need to swap again..
for this part i assume you have a 4wire o2 harness side plug to work with..
now the 4wire o2..
you got one wire hooked up.. now chop off your old o2 sensor plug on the cx harness.. and that wht wire hooks up to the wht wire on the new 4wire o2..
next.. the black/yel wire.. that connects to the lil capped off plug on the drivers side of your engine bay.. since you had cx.. you should have one plugged pin hole.. where you can insert another pin.. if you cant do that.. im pretty sure you could just run it to any yel/blk wire..
lastly the grn wire.. that connects to any grn/wht wire in the harness.. i think iac, tps, map and the water temp sensor on the water neck all have it.. just choose whichever is easier...
have fun.. like i said.. aim: gettruent if you need help.. if you think it's over your head.. dont feel bad.. leave it to the pros.. you can always send me your harness i'll have it done in no time
