hey guy im doing a ls/vtec i drive a 1993 integra i just need to know what ecu should i use and this mit sound crazy but what distur do i need i got the ge kit and the arp studs
run a p2t ecu,im not sure if its obd2 or obd1.but if it comes down to it,you can chip a p28 and have it basemapped for your setup,i know someone in CT that will do it right in front of you for $75.. and im from newlondon/groton,,but right now im living in colchester
if its all obd1 then yes..the only thing youll have to do is get the vtec subharness,,and run the wires to the solenoid.(after the head is on and oil line run)
i started off with a p30(eventually went with a chrome chipped p28) on my 94 ls/vtec dc. it ran good with the p30. i also used an em1 head but i used an obd1 vtec dizzy and i had no problems.
