What Else For Ls/vtec
Discussion in 'Engine Building' started by tnsxsear, Jan 21, 2003.
  1. tnsxsear
    tnsxsear Senior Member
    What else do i need to get my ls/vtec to be pretty quick and what do you all suggest i get extra. This is all the stuff i have as of right now.
    My car is a 98 civic cx hatchback..
    99 b18b1 block already tapped for oil lines.etc..
    00 b16a2 head
    00 b16a2 transmission
    00 CTR cams, int & exh
    00 p73 ITR pistons on ls rods
    new centerforce clutch
    new arp headbolts for b18b1
    new headgasket for b18b1
    97 obd2 p72 ecu
    Things i need:
    VTEC oil pump and watter pump
    Thanx in advance -Paul
  2. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
  3. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Do you already have the ITR pistons on the LS rods?
    Sell the B18B ARP head studs and buy the ones for the B18C1, the LS head studs won't work. You need a GSR timing belt. If the bottom end is not assembled yet you will need new piston rings. Basically the more that you can replace now the better. What rod bolts are you running?
  4. tnsxsear
    Yeah the pistons are already on the LS rods. and they have new rings also. The ARP bolts are already on the block and they are for the LS. as for rod bolts, im not sure. a friend assembled them for me. and im using the ls timing belt, but i will get a gsr one if i get the vtec oil pump... anything else i should do?? thanx everyone.
  5. civicracer901
    civicracer901 Senior Member
    Clearwater,FL.
    sounds like a good setup to me for starters. I would work with getting it tuned stuff like that.
  6. lsvtec
    Are you saying that the ARP LS head studs are already on the block with the VTEC head? I don't think that is possible.
    As for the timing belt, oil pump has no effect on the timing belt you need. The oil pump is driven by the crank. Water pump determines which belt you use. If you use a VTEC water pump you need a VTEC belt and vice versa.
