What Engine do you recommend?
Discussion in 'Engine Building' started by VenomSi, Jan 4, 2009.
  1. VenomSi
    VenomSi New Member
    Hey guys, i had a quick question to ask you. I'm new at this so i need some advice. I just bought a 2000 Civic Si coupe and am planning to completely build the engine and thereafter put on a Turbo. I'm looking to pull roughly 500-600 hp at the crank. What motor will be the best option for me?
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
    -Sigh- Please :readfaq: Then ask that question again, btw welcome.. and that much HP ask Central Flordia Turbo... lmao
  3. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    You could build up your B16 but really though, are you ready to spend some serious cash in your build? Not to mention upgrading your suspension and brakes. After all, it's not worth it to be able to go fast if you can't stop or if your car can not handle the power.
    Lets look at it this way. What is your budget right now and time frame goal?
  4. VenomSi
    VenomSi New Member
    This is going to be a roughly a years project and am willing to spend around 15-20k
  5. serrilion
    Vermont
    Cough* Bring it to a tune shop throw 15K and say I want to Go FAST! LMAO, sry just had to say that!
  6. Luis998
    Orlando, Florida
    In that case, just to make things easier on yourself, I would suggest dropping it off at the shop of your choice, letting them know what you want, sit back, relax and await the finished product. If you have that kind of money up front that would be one way of going about it. However, if that is not the case, you could go around looking for parts that are specific to your build, save yourself a buck or two, still finish on time and enjoy.
  7. VenomSi
    VenomSi New Member
    Well i'm doing this just to enjoy the process of doing it myself. I already did that with my M6, so I kinda want to do this on my own. Any suggestions you can give me would be appreciated.
  8. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just keep the stock motor it can get those numbers easy with new parts
  9. George777
    George777 ^^ Likes Bewbies
    With your mom
    K swap bar'd w/juice
  10. INJEN78
    INJEN78 HS LEGEND
    OHIO
    if its a DD then dont do anything to it,if youve got time,pull the motor and build the hell out of it,or do as george said,,K swap
  11. 97hatch
    97hatch ?
    Anderson IN
    sleeved gsr block
    pistons
    rods
    machine work
    use b16 head
    stainless valves
    valve springs
    good set of turbo cams
    better get some cam gears
    hondata
    wideband of some sort
    1000-1500cc injectors
    walbro 255 fuel pump
    drive shaft shop axles stage 5 would be best
    lets say maby a twin disk tilton clutch
    liberty handcuff for trans"you will now have a 4spd but case shouldnt split apart on back side"
    turbo hum lots of options i would sugest a full race kit
    big brake kit
    1in master cyl
    may i also sugest at least 6pt cage as a 500-600hp civic is going to run mid 10s
    have fun
    be prepaired to rebuild botom end at least 1-2 times if you are a beginer at tuning and you plan to do this yourself as you will blow it up
    lots of other stuff
  12. Magana559
    Magana559 The Warden
    fresno Ca
    I Would Say Boost A LS First And Get A feel For boost, THEN Go Ahead And Spend $20k On Full Build.
  13. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
    LS7 and call it a day lol
  14. ArmyGreen
    ArmyGreen New Member
    Green, OH
    Im in agreement either a k swap or a b18c
  15. AHHVTEC
    Alabama
    it would be a waste of money and time to put another b series in there, when it already has one
  16. serrilion
    Vermont
    I Agree :) HEHE, Maybe he can Turbo it after wards haha!!! :) 1k HP civic :) Sounds like a fun time:D
  17. ratyS13
    ratyS13 New Member
    Akron
    b20 block sleeved
    keep your head
    gsr cams
    upgrade fuel system
    gt35r
    tune
  18. 95b16coupe
    95b16coupe New Member
    ct
    1) buy blown b-series
    2) put it on engine stand
    3) buy aforementioned parts
    4) install parts and engine into car
    5) keep stock motor to install if you have problems with turbo
    6) buy really good brakes
    7) get insurance for it all
  19. newb
    newb phresh VIP
    Backwoods Northwest
    No joke. Why buy things twice, even if your budget will allow? Pull your motor, sleeve it, forge it, boost it. Give it the tune that its worth, and enjoy it.
  20. je power
    je power New Member
    my house
    i would say go wit a b16 if i had to choose
