What Engine Is In An 88 Perlude Si?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by the_hulkamaniac, Jan 18, 2003.
  1. the_hulkamaniac
    the_hulkamaniac Junior Member
    Its sort of as simple as that I have a friend with one. The car is toast but we just put a new motor in it before it was smashed. All I know is its a 2.0L, could some one say the model code? Where do you read it on the engine?
    Also is there a guide to what all of these engine codes mean (ie. b16 / h22)
    I just want to learn where they came from and what there good for.
    Thanks!
  2. E_SolSi
    i think it has a B20A5
    the code will be stamped on the engine... look for a flat square near the tranny
    for info on engines click on the "reference" tab at the top of the page
    then click on "engines"
  3. gwade1966
    gwade1966 Junior Member
    According to Sport Compact Car ("The Ultimate Honda Engine Swap Guide"; December 2000) and Tuner's Alliance, the '88 Prelude Si has the B20A4 engine. Both of these sources are good starting points for learning about the various engines. I'm still doing research myself.
  4. rush101
    rush101 Junior Member
    I do not believe there is a such thing as a B20A4. An 88 Si has the B20A5 which is rated at 135 hp and 127 ft. lbs. of torque. The plain S model has a B20A3 which is carburated and weak. Anyway, hope that helped.
  5. lsubluelude
    lsubluelude Junior Member
    I think there is an A4 in Europe, but I could be wrong. That car came with either an A5 or A3, which really doesn't matter anyway, because they are basically the same exact block. I am still trying to find out what the differences are.
  6. civicSiR1
    civicSiR1 Senior Member
    The B20A4 is different from the other B20Z.....so becareful, you might just get messed up doing a B20 vtec conversion.
