What engine
Discussion in 'Engine Building' started by lkvonhall, Mar 16, 2008.
  1. lkvonhall
    lkvonhall New Member
    I'm confused on all the different engines and sizes available in Honda. I have a 1990 CRX SI. How do I know which engine I have?? Also, please give me the "slang" name of it. Thanks...
  2. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    On the block, right where the transaxle/transmission bolts to the engine block there is a flat spot with a stamping on it. It may say D15 with a letter after it. It also may say D16 with a letter after it. That is where to locate the exact engine code. As for the "slang", they are pretty much just called single cams.
  3. GlassHeadlights
    Calgary, AB
    if its a si it should have a d16a6 a fairly strong motor i might add mine hs almost 200 miles and still running strong;)
  4. lkvonhall
    Thanks for the info...:)
