i have an HF bottom end and i blew a head gasket so i tore that apart today now im working on which head to put on, Hf head is garbage, turns out it was cracked and had seals leakin like crazy, so these are the parts i have right now.... HF, A6, and Z6 cam gears, a6 and HF timing belt, and the Z6 head... anything i can make work from that? i was thinking puttin the HF cam gear on the Z6 head and using the hf timing belt , would that work? any help please
thanks TJ
thanks TJ
