Engine and trans mounts from hasport, enjo, etc
Axles from hasport, dss, etc..
Youll need a swap header, dc, dtr, r crew, etc
Custom intake or shell out 200 bucks for a new "hybrid"one (made for k swaps)
Youll atleast need a hondata reflash
fuel pressure regulator
Shifter cables and box
radiator adaptors
fuel rail
fuel pump
clutch lines and clutch if you dont want to use the stock one, if you even got the stock one...
ep3 pulley stuff, not exactly sure on the exact name
probably a custom exhuast unless you want an undersized one that most aftermarket ones are for d16 civics. (id go with 2.5 inch piping)
fuel lines
i think thats about it, more or less.
K20A.org .:. The K Series Source . Honda / Acura K20a k24a Engine Forum is a plethora of info on k swaps, check that site out too.
