What Injector size to use with 185HP LS/VTEC ?
Discussion in 'General Tech and Maintenance' started by mdixonjam, Jun 9, 2005.
  1. mdixonjam
    mdixonjam Member
    Kingston, Jamaica & Miami, FL
    I have a 1995 Integra with a LS/VTEC engine with about 175 HP and doing some mods that would probably take me up to about 180 - 185 HP.
    I currently use a set of 270cc fuel injectors.
    Are these adequate for my application ?
    If not, what size should I get - 310/320cc, etc ?
    Thanks
  2. pissedoffsol
    more than enough. the stock 240cc's are good for 190-ish whp.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Keep your 270s until you're making obscene amounts of torque.
  4. HollowJDM
    HollowJDM Senior Member
    you dont need more then that until you add forced induction, then youll go big.
  5. sohcslammer
    sohcslammer Senior Member
    Bay Area
    I have always heard that the 240s are good up to around 200 hp and then you want the 270s. 250 hp you would run 310s and anything more and you are running boost... :)
