honda motor have a harden sleve inside to aid in strength and longevity
due to the aluminum blocks the combustion chamber had to be made from steel and put indside the block
when you resleeve the block you replace the factory sleeves with after market which are stronger you usally go with solid deck sleeves which block of the top of the cylinders to creat a closed deck
