ok i just got my zc in my crx. Now when I drive it and hit a bump (while still on the throttle...) the engine check light comes on and the motor studders, then it'll stop and the check light turns off. Its also not running strong either. I checked the ecu and its blinking out 17...does anyone know that error code? thanks
Error 17= Vehicle Speed Sensor Its your speed sensor about to come out on the tranny or the cable, etc. Or atleast, that's what an error 17 is. I could be wrong though
yeah definitly sounds like something is loose, check connections, esspecially sensors such as TPS and map if it only does it while on the gas...
