What is the death possibility when
Discussion in 'Engine Building' started by lsvtec, Aug 18, 2005.
  1. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    So I was driving back to work yesterday when I shifted from 8000 in 1st to 2nd gear and the car lost all power. I stopped on the side of the road and it would idle but would not rev over 1000 RPM with the throttle floored. Turns out my intake gear slipped. What are the chances that I bent the valves and how can I know if this car will handle a 30 hour road trip without access to a leak down test?
  2. formby
    formby learning in progress
    wow....where have you been???????
    anyway..... put it back on and see how it runs....but i dont think you should drive it like that
  3. reckedracing
    reckedracing TTIWWOP VIP
    NY
    chances are very high for a bent valve...
    especially at 8K
    reset the timing and drive it...
    bent valve will usually cause rapid erosion of your valve seals so expect to see black smoke in your rear view in the near future...
  4. lsvtec
    My options are drive it 30 hours to home or donate it to someone here and fly back. There is no way for me to ship it as shipping costs almost what the car is worth at this point. (especially with a bent valve :( ).
    As for where I've been, stupid busy with school and then and internship at IBM this summer. I'll be back more this next semester hopefully :p
  5. E_SolSi
    depends on how far the cam gear let it go
    id adjust it back to where it should be and see if its drivable
    had this happen to me a while ago and everything is still fine
  6. reckedracing
    NY
    donate it to me, i'll pay shipping
    lol
  7. lsvtec
    It think that it slipped all the way and it happened in VTEC. On one hand it idled fine, but on the other hand I haven't had a chance to drive it and I need it to last for about 2000 miles to get back home. Is it worth the gamble?
  8. Speedracer228
    Speedracer228 ......
    id say set it back to where its supposed to be and listen to it, drive it around a lil then go from there....
  9. phyregod
    phyregod !!YTINASNI
    Central Texas
    If you decide to donate it I'll come pick it up. Seriously.
    I'll even give you some money for it.
    phyregod@earthlink.net
  10. E_SolSi
    welp my skunk2 gears slipped on me when i was well onto the high lobes (my fault not the gears :( ) ... they went all the way to the edge of the opening not sure how far it was but it was over 10deg.... the car ran like shit.... wouldnt rev, had no power, barely idled, finally wouldnt start at all.... after checking a whole bunch of shit i finally figured out what happened.. set the gears back to there they were supposed to be... made sure thay all of the screws were TIGHT on both gears... made sure the timing was still rignt... havent had a problem since
    so dont mark it as dead yet
  11. b204dr
    b204dr Senior Member
    Minnesota
    lol bent valves/bad valves seals slowly die- my car ran crappily for 100 miles and died !
  12. wanderinman
    wanderinman Senior Member
    Raleigh, NC
  13. E_SolSi
    and mine has been running strong for about 2 years now
    :shrug:
    its a toss of the dice i guess
  14. lsvtec
    Durham, NC
    Well, I suppose there is hope then because the gears were set back and the car seemed to run okay, I am going to ask the shop to do a leakdown on it and see if they acn tell me anything.
  15. wanderinman
    Raleigh, NC
    I'm outta Raleigh, and if you need a boy of mine is a Honda tech locally here. PM me if you need any help (or if you want to sell me your car, lol)
  16. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
  17. lsvtec
    So it survived the trip home, I guess I lucked out with no damage. Thanks for eveybudies help.
  18. E_SolSi
