what is the rpm range of a t4t-61 turbo?
turbowagon92
whats up,i am putting a t4t-61 turbo on a built h22a1 accordwagon this week.i want to know the rpm the turbo starts spooling up?:confused: what is a reliable rpm range for this turbo and actual rpm boosting range of this turbo?
umm a guess wouldbe 4200 you might get full boost. idk put it on and let us know.
what you mean by reliabel rpm range for this turbo/rpm boosting range. its good till redline. ??????
I'm using a T3/T4 57 trim .63 turbo on a D16, 2.5 piping, starts making boost at 2500, 5 psi at 3500, 12 psi at 4k with wastegate kicking in.
T3/ T4 .50 compressor, .63 turbine, 57 trim, Google Ray turbo and use the Java program to see which turbo map is best for your application. In my case after I entered the motor specs it said I would hit the sweet spot on the 57 trim at 10 psi, which it did. Its nice when the math matches the real world.
