What Is This Haness From
Discussion in 'ECU's, Electronics, and Tuning' started by 90vtec, Jan 8, 2003.
  1. 90vtec
    90vtec Senior Member
    I cut out a civic harness from a bad wreck and thought it was a 92-95. Now Í'm not sure.
    It has a total of 3 plugs (one plug is divided into three parts) and three colours
    The first plug. Is actually 3 seperate parts. It is grey.
    Each plug has 3 rows of connector and each row has a number of wires going to it.
    The Second is is blue.
    The plug has 3 rows of connectors but only 2 actually have wires running to it.
    The third is green.
    The plug has two rows of connectors and wires.
    If you could tell me if this is from a 92-95 or a 96-00 that would be great. Any picks of the ECU male end of the connector would be great too!!
  2. Ima2nr
    Ima2nr Member
    the harness you just described is the OBDII (96-2000) harness.
    the OBDI (92-95) harness has 3 roundish grey plugs on the passenger side and 1 plug on the drivers side.
    another way to tell the diffrence is the OBDI harness has two distributor plugs, and the OBDII harness has only one.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    The 92-95 has more than one tower shock connections at the drivers side.
