What is this noise?
Discussion in 'General Tech and Maintenance' started by mtnbkrpnk, Feb 3, 2004.
  1. mtnbkrpnk
    mtnbkrpnk Junior Member
    Upper Marlboro, Maryland
    I drive a 97 DX coupe, I have 79000 miles on it, and over the last few weeks I have had a rattling noise coming from under the dash. It only does it when the car is at a standstill. As soon as I add gas in gear it stops. i was thinking an AC compressor, but I don't know alot about mechanical stuff yet. The heater and AC can be on or off and it acts the same. Any ideas??
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    start it up and look underneath the dash with a flashlight is the only thing i can think of, make sure its not anything in your glovebox first
  3. mtnbkrpnk
    It's definitely mechanical, but I will pull the dash off and see if there is anything out of the ordinary.
  4. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    dude as soon as you hear that noise.. run around your car like a mad man and find it .. lol pop your hood and listen look under your dash.. make sure its not something stupid like xyswany said.
  5. MXDesa
    MXDesa Senior Member
    Queens, New York
    Empty out your dashboard. Most like (At idle) an item is vibrating around which doesn't happen at accelleration or stopping because the idle is more steady and smooth.
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    some shit loose under your dash,, inspect and try to find the culprit
