what is this?
The HF or Y7 manis are the best candidates, the Y7 you have to cut the cat off and just weld a flange on, the HF youll need to make an adapter plate for.
CHRYSLER Conquest MHI TD05
Junkyard Turbo List
what you have is basically a Mitsubishi turbo (same one that came on a Starion) and should work well .. you can hit the 200 mark pretty easily
Yea 200 doesnt seem too hard but the biggest thing is tuning. As for the manifold im getting a stock y8 exhaust manni and having it welded to the turbo, only becwuse the manni is free and so was the turbo.. (i dont want people to think i steal shit... Its a junkyard and theese guys are fucking assholes there and wanted to charge me 30 dollars for a set of used corrner lights i told them to fuckk of and went and bough a jdm knock off pair.)
You do realize that you cant weld 2 pieces of cast steel togather, right?
That aside, how is welding em togather gunna make ppl think you didnt steal it?
I have seen people use nickel rod with an oxy torch to weld cracks in cast iron, I think it would work to weld it too. the trick is finding someone who is willing and able to try.
That may work, but fixin a crack is a lil different then bonding to completely different pieces. Id be very nervous on the first heat cycle, thats for damn sure.
