what mounts can i use?
Jason808
I have a 99 honda civic 2door. what mounts can i use to drop in a obd0 91 B18A1 motor?
my friends tell me that i can use the stock ls integra mounts..is that correct?
thanks-
No, your friend is wrong. You MUST use the 96-00 civic mounts. You will have to change out the drivers side engine mount to this drivers side bracket because the b18a1 bracket won't work with the 96-00 mounts/chassis.
Also, on another note. Are you planning on using the b18a1 original cable transmission? If so, you will need a cable transmission conversion mount and hydro to cable conversion kit for the clutch. You can find the conversion mount and actuator kit as a complete package like this 96-00 civic B series cable transmission conversion kit.
Another thing worth mentioning, if your driver's side engine mount is still the stock one, it will break very soon with the B18 in there. I would REALLY recommend just getting a full mount kit.
