what needs to b done
Discussion in 'Motorcycles' started by vpower, Feb 16, 2012.
  1. vpower
    vpower New Member
    L.A.
    I have a 06 gsxr1000 that's hasn't been turned on in abt 3 years...I know I should drain the gas tank because of moisture build up, new oil and oil flush...lube the chain....anything else that needs to be done before startup...thanx For your advice
  2. E_SolSi
    you could put the back tire in the air, put it in gear and rotate it to turn the engine over a few times and get things moving a bit before firing it up... otherwise what you listed looks fine
    crank that fucker up
  3. vpower
    vpower New Member
    L.A.
    Thanx for that info because that sounds like it makes some sense...also someone also told me I should drain the oil from the throttle bodies??? Is there a reason y I should do that???
  4. E_SolSi
  5. vpower
    vpower New Member
    L.A.
    Okay...I was thinking this guy is crazy, but it does make me wonder what if he is right
  6. 99sidude
    Ohio
    He probably means drain the fuel in the throttle bodies. The fuel system will have some old crappy gas in it that won't drain when you drain the tank.
  7. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    I'd say if you got the tank changed screw it. Floor it.
  8. vpower
    vpower New Member
    L.A.
    ^^ lol...I actually try not to abuse it...draining the fuel from the throttle bodies shouldn't b that tough...I like to have my shit reliable....probably not best to cut small corners...thanx for all the advice now gonna start getting this shit rolling
