What now? I cant figure this one out...
Discussion in 'Forced Induction' started by broadheadjohn, Mar 16, 2007.
  1. broadheadjohn
    broadheadjohn New Member
    Hey guys...first post for me. I have been reading for a while....
    Anyway I just put a turbo on my 99 gsr, this is my first turbo application and first honda after many superchargers. I just got it installed and put 440 injectors in it. It is definetly not running right. There is ALOT of hesitation at the beginning and it is blowing off under load at higher rpms. Also there is a stutter when you hold steady under load(about every 2 seconds). I have a couple opinions myself but I'd like to see what you guys have to say. Thanks in advance for your help, it is appreciated.:)
  2. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    what are you using for tuning? are you familar with tuning any cars?
  3. broadheadjohn
    I am very unfamiliar with tuning... I have used preprogramed stuff on other vehicles but no honda's. I have a
    ??? "boost controlled fuel pressure regulator"??? from the used kit I got but I don't know how the hell to put it on, or if that is what I need. I don't have a hondata or anything like that, my brother said I could tune it with a safc but I don't trust everything he says. I kinda assumed it is a rich fuel problem but what do I know... I would rather not spend the $$$ on a hondata and just use wht I have but let me know what you think... Thanks, John
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    you NEED fuel management.
    Any idea what kind of boost you're feeding your motor?? BOV malfunction?
  5. broadheadjohn
    Its running 8-10#'s... As far as a BOV malfunction I doubt it. We did a car to car swap right in the same garage and it was working fine on his car.... Mabey could it be a vacuum issue????
    Will a rising rate fuel pressure regulator work well enough I won't need a expensive fuel managment system???
  6. arf4n
    arf4n New Member
    UK
    what your doing is basically giving it more legs but it doesnt know how to use it, it... if that makes sense ^_^
    you either need;
    AFC hack - its ok but doesnt do anything with timing
    FMU - errghh no thanks
    or best way;
    chipped ECU with some sort of program (crome, hondata etc).. get xenocron (Crome, TurboEdit, Uberdata --- DIY Honda ECU tuning and chipping resources, products write-ups and links. Widebands, Fuel Pumps, Intercoolers, ECU Chipping, Wideband Tuning & more) to get you to do a basemape, then you can run you car like that (not recomended) or/and take it a shop and get it tuned..
