What Octane To Use
Discussion in 'General Tech and Maintenance' started by brc80, Feb 7, 2003.
  1. brc80
    brc80 Senior Member
    Southern California
    With a 10:2:1 compression, what octane gas is the lowest i can safely run, and at what compresion levels do i need to start running higher octane gas? Tahnks for the help guys.
  2. gtpilot
    gtpilot Member
    You might be able to make some generalizations about octane rating and compression ratio...but it is just guessing. The head design (combustion chamber), piston design, valve area, IM and EX flow characterstics and camshaft have too much effect on the dynamic compression which is acutally what utlimately drives how much octane you need to prevent detonation.
    Kirk
  3. RFHOMI2U
    RFHOMI2U Senior Member
    To the best of my knowlege, and experience, most motors over 10:1 would run best with 93. Even my Z6 runs like crap with only 87. Run 93 for best performance.
  4. chevy302dz
    chevy302dz Senior Member
    Start high and work your way down. Your engine will run best on the lowest octane that does not lead to pre detonation under load. If you just want a real generic guess at least 91 octane.
  5. wildbillhatchbac
    wildbillhatchbac the OG VIP
    recommend 93 but it will run (like dog sh!t) on 87
  6. brc80
    brc80 Senior Member
    Southern California
    does anybody have any good recomendations for a good octane booster, in cali we only have 91 pee water, and if it makes any diffrance its a 1st gen b16a, thanks
