What OEM Honda/Acura CD players will fit?
They should all fit if they are a Regular Din sized unit which 3/4 of them are. The only thing I would question is if the factory Wire harness is still intact in your car or did someone Butcher that plug off.. If that is the case and the Harness is cut then you need to get a Reverse Honda Harness..
With the Company Metra the part # is a 71-1720 for most hondas up to 98 for the Factory Radio.. After 98 the Harness part # for the reverse harness would be 71-1721..
thats awesome audio. so what youre saying is a stock honda cd player will fit into any year honda as long as its older than a 98?
As long as its a Din Sized which is 3/4 of the Honda Radios.. You can fit a 98 and Up radio into the Car but the Wire harness will be different. If the Pre-98 Car still has the factory harness into the Car to make a 98 and up Radio work you would need to find 2 aftermarket harnesses..
You would need the Metra part 71-1721 Reverse harness that would plug into the factory Radio above 98 and then the other Harness is a 70-1720 for the Harness that would fit into the factory harness plug on the Pre-98.. Now these are all Metra Part #'s (which is the brand I sell).. But other companies do make them but these are the part #'s for the Metra Brand.
