what part is this?
Discussion in 'HYBRID -> EG-EK / DC' started by wickedplastikman, Nov 1, 2004.
  1. wickedplastikman
    wickedplastikman Senior Member
    chicagp
    i am swapping out my ls motor and putting a gsr in. i found this piece and dont know what the hell it is or where it goes. it has 3 bolt holes. 2 are facing left and right and 1 is facing up and down.
    http://www.hondaswap.com/forums/uploads/10..._1099362200.jpg
    also. the gsr block has a hole to the right of where the oil filter goes and on my ls it is just plugged. anyone have an idea what goes in there? the pic is sideways.
    http://www.hondaswap.com/forums/uploads/10..._1099362243.jpg
    thanks.
  2. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    the top one is a lower engine stiffener or something close to that- it bolts the trans to the lower part of the block- I'm honestly not sure if LS motors have them, but I know that GSR's do
  3. brian11to1
    brian11to1 Senior Member
    Its the bracket that bolts to the bottom of the engine and to the side of hte tranny, there should be 2 of them 1 slightly longer than the other. You need to reinstall these.
    As for the hole, I dont know... probably something for Oil...
  4. brian11to1
    Yes LS's have them B18A's and B18B's.
  5. Slammed90Lude
    milford, PA
    oh ok- I just remember bolting and bolting them on my GSR swap- But when I did the LS in the integra i didn't put in a new clutch
  6. wickedplastikman
    chicagp
    thanks. ill check it out tommorrow and make sure. anybody have any idea what that other hole is for? or is it supposed to be like that?
  7. Johnnylawless
    Johnnylawless Senior Member
    the last pic shows an open hole. that is where the breather chamber- oil /air seperator canister fits in there on ITR Block it is rectangle, large hole at bottom with o-ring and two small holes at top
  8. wickedplastikman
    chicagp
    i see. i need a breather chamber. thanks. anyone know where i can find one for cheap?
  9. brian11to1
    I thought those were a little more to the right (towards the tranny)?
  10. projekteg
    projekteg Senior Member
    i've got one laying around, it's not in the prettiest condition, but nothing a little degreaser and black paint won't take care of. pm or email me if you want it.
  11. nfn15037
    nfn15037 Senior Member
    The extra hold is for a knock sensor. It is hard to tell in the pic but the GSR has one and the LS does not.
  12. projekteg
    ummm, no, rotate the picture 90° ccw to get the true straight on view, then tell me if that's where a ks goes ;)
  13. brian11to1
    Yea, I second the KS statement. The oil filter is just above it... why would hte breather chamber go below the oil filter?
  14. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    nope. knock sensor is above the oil filter, and above the coolant tube thingie.
  15. Johnnylawless
    as he said the pic is sideways !!!!
  16. civicious
    Houston, TX
    no shit, douchebag...
    the knock sensor would be to the RIGHT of the oil filter in his pic.
  17. Johnnylawless
  18. civicious
    Houston, TX
    edit: What the fuck is your deal? Why the fuck would I not be able to fucking figure it out? The knock sensor is ABOVE the oil filter...or, in the case of his picture (which is sideways), the knock sensor would be to the RIGHT of the oil filter because his pic is SIDEWAYS...
    WHICH IS WHY I FUCKING SAID THAT THE GODDAMN HOLE IS NOT FOR THE MOTHERFUCKING KNOCK SENSOR.
    SO GET THE FUCK OFF MY ASS
  19. Johnnylawless
    officially off your ASS. sorry if I let go on you ( civicious) I was trying to help this guy out figuring what that big hole was for, not the treaded hole. maybe I didn't read it right.
    Again sorry, civicious
  20. civicious
    Houston, TX
    Hybrid89 had like 10 of them for sale a few weeks ago, I'm sure he still has some...PM him and see
