What pistons to use on LS motor
Discussion in 'Engine Building' started by 94CivicSlow, Mar 14, 2005.
  1. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    I have a95 b18b1, I read the P30 JDM B16A pistons are a good choice.
    All I can find is the B16A2 pistons for sale.
    Can I use these pistons, and if I do, what is the expected compression ratio?
    Will they clear the crower 403s?
    (I searched)
  2. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    Here is a link to figure out what your compression would be Compression Calculator. The b16a2 pistons are good too for your setup. There shouldn't be clearance issues with your piston and cam choice. If you are still worried email Crower.
  3. brian11to1
    brian11to1 Senior Member
    But, you should clay the motor if you have any doubts. Check out C-Speeds Tech site on how to do this.
    Brian
  4. b18_4door
    b18_4door Member
    sup man..i got a b18a also.. p30 pistons with 403..no clearance issues at all..11:1 compression ratio
    awesome ass pistons for LS ;)
