What Preformance Pistons Cad Do?
Discussion in 'Engine Building' started by hondacivicnos, Feb 26, 2003.
  1. hondacivicnos
    hondacivicnos Senior Member
    What preformance pistons cad to do b18c5...
    I mean whats a difference between new one and b18c5 that I have right now?
    Whats changing if I will swap new once in it?
    And the Valve Springs whats a difference between them? And should I get new Springs if I will swap new cams in?
  2. cbrnascar0329
    cbrnascar0329 Banned
    not sure what your trying to say.......?
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    depends on your pistons or cams, your question is wayy to general. do some reading on the internet about how engines work. you might find some good base info at http://www.howstuffworks.com
  4. 96hatch
    96hatch Junior Member
    the higher the compression, the more force that will be place on the top of the piston every time cumbustion occurs. this will force the pistons down harder which will make the crank turn faster and harder , which in turn will give you more power. that is basically what goes on.
    yes you will need new valve springs if you upgrade the cams.
  5. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    you don't have to change the springs out, it's recommended and you should, but you don't have to(depending on cam and application).
