What rc injector size should i run with this t3/t4
brasilianstreet
Well im using a turbonetics t03/t04 e turbo charger to boost a integra b18b Ls engine which is swapped in my ek hatch and im going to run like 8 psi and i dont know that DP or Turbo mani yet but is there any way someone could tell me what size injectors i should get ?I was thinking 550cc but i also had 1 size bigger in mind aswell.
550's are fine for 250-ish
ph vs sat-
there's a write up in the tech articles.
neither is better so to speak- just a different method.
your car is wired for saturated.
if you go to p/h, you will need to wire in a resitor box.
Alright thankzguys yea im sticking to buying saturated anyways ill go with 550cc now and NOTURAVERAGESI are you talking to me aout the question or another brian?
they are peak and hold so you'll have to run the resistor box. THey are 550s never installed straight from RC with flow test paper work. What do you want to pay for them? They retail $95.42 each from RC.
