what rim/tyre combo to use??
Discussion in 'Wheels / Suspension / Tires / Brakes' started by The Godfather, Nov 4, 2011.
  1. The Godfather
    The Godfather New Member
    Hi,
    my eg civic has a h22a with a bit of work and came with 17" low pros on it which are useless in 1st and 2nd gear, nothing but wheel spin - can even drop back from 5th to 3rd at 100kph (60mph) and she will spin for a few meters :cool:
    ive been searching for some 15 or 16 inch rims with maybe a 55-60 profile to run a bit less air pressure for traction from a stand still/drags.
    few dilemas -
    my eg has prelude front brakes and not sure if 15's will fit?
    i want to run 225 wide and am thinking it might hit/rub the suspension?
    just wondering what everyone else runs with similar power levels.
    thanks
  2. The Godfather
  3. 98EkSi
    98EkSi New Member
    I run the stock 14" Hx rims on my civic rapped in Falken 195/60 R14. This had been a pretty good combo for me. Good grip and tire wear and some of the lightest rims you can find. I also think the Hx rims look good. JMO. IMO anything over a 16" rim is to large for good performance. I ran some 16x6 rims years ago on my old Accord with Nito Extreme Performance tires and really liked them as well.
  4. h22a hatch
    h22a hatch New Member
    im thinking the same thing i have a the same h22a swapped eg hatch and have shitty as steelies on right now n spin sooo much goin from a dig and 1st gear roll..im looking at rims and i was wondering what the widest rims u can run without rubbing would be??
    i found a set that i like that come in 7.5inches wide and 10inches wide...i kno the 10 sounds like overkill but down the road i plan on spraying and might need the xtra grip
  5. E_SolSi
  6. The Godfather
    Well bad news I can't run 15's :(
    I tried a set of 15's on last night and they foul on the calipers
