What rods will fit in a d15?
Discussion in 'Engine Building' started by esi42, Mar 14, 2004.
  1. esi42
    esi42 Member
    Hey whats up.
    I was wondering if you can fit a set of stronger oem rods in a d15b2 block. I have a set of 86 integra big rods. What is the difference between the 1.5 and 1.6? Is it bore or stroke or both?
    Thanks
  2. esi42
    esi42 Member
    Anything?
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Stroke only.
    D15 = 84.5mm
    D16 = 90mm
    D15 rods are about 3mm shorter than D16 rods (not sure of exact length), so you can't use D16 rods or Integra D16 rods in a D15 without punching your pistons through your head.
