I built an LS/Vtec motor for my Austin Mini. I was wondering what size injectors I should use. I have JE 11.5-1 forged pistons and the head is milled a little, AEM fuel pressure regulator, STR fuel rail, DC Sports header, Accel DFI gen 7, block guard, clutchmaster flywheel, ACT clutch, GSR transmission. I will be adding an aftermarket intake and adjustable cam gears at a later date. I was thinking 310cc injectors, but I am not really sure. I am going to make some calls tommorow, but figured I would see what you guys think. You can see what I am building here http://webpages.charter.net/jevs/vtecmini.htm
I am finally getting back to it after a year of working on everything else but my Mini.
