scottp11
The Seniorest Member....
I have a 93 Civic hatch with a JDM B16A (10.4:1 cr) swap. I ordered a turbo kit from Drag Turbo Kits with a T3/T4 turbo and 7lb wastegate spring. I was going to order the RC 310cc injectors with the kit, but everyone I talked to said that they were too small. I had to atleast get 440cc's. What size should I get. I have the Walbro fuel pump, and Eagle fuel rail with an adjustable FPR. Do I even need to get bigger injectors, or will my stock one's work fine? I plan to get Hondata S200 also, and have an OBD-1 P72 ecu right now.
I don't plan on turning up the boost, cuzz my engine is not built at all. Stock sleeves, pistons, rods, etc... Thanks for all the help and input!
