What Size Injectors?
Discussion in 'Forced Induction' started by Ractive78, Mar 26, 2003.
  1. Ractive78
    Ractive78 Senior Member
    Virginia, USA
    I want to know want size injectors I shoul be using on a b18a with t3 @ 10 psi.
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    what fuel management are you using?
  3. pissedoffsol
  4. Ractive78
    Virginia, USA
    Haven't decide on fuel management, I was planning on using the s-afc hack, then later on getting hondata.
    To run 450's, dont I need to get a different resistor box, because my integra will supply it with to much voltage or something of that nature? Are dsm injectors any good? Ive heard they were crap.
    And how much hp could i get from a t3 (A/R of .42 on the cold side and A/R of .48 on the hot side) @ 10 psi on stock internals?
  5. EFtypeR
    EFtypeR Junior Member
    According to the math, and your stock ECU, you should use 330-340 cc and very little adjusting with the AFC. Dyno it for better results, don't trust your butt-dyno.
  6. Ractive78
    Virginia, USA
    Where do I get 340's and are they capable of suppling enough fuel, with turbo pushing like 9 psi?
  7. EFtypeR
  8. Ractive78
    Virginia, USA
    Would they be capable of keeping up with the fuel demands of an engine running on 9 psi?
  9. pissedoffsol
    i'm telling you, run at least 440s.
    you DON'T want to max out the duty cycle, and being a little over kill won't hurt you if you tune it out for a good idel
