What size is the ITR Clutch Master Cylinder ?
Discussion in 'General Tech and Maintenance' started by mdixonjam, Jun 14, 2005.
  1. mdixonjam
    mdixonjam Member
    Kingston, Jamaica & Miami, FL
    I was wondering if the Integra Type-R uses a bigger Clutch Master Cylinder than the other Integras ?
    I think the others use a 5/8" clutch master cylinder.
    Anyone knows what size the Integra Type-R uses ?
    I hear the bigger the piston the better your shifting (same principle they use for the Omni-Power Quicklutch Master Cylinder upgrade: http://www.omnipowerusa.com/Products/Produ...er_Cylinder.asp ).
    I was also wondering if upgrading to the Type-R would have a similar effect, but not as aggresive as the Omni-Power's ?
    Thanks
  2. pissedoffsol
    oops- moved you there by accident.... moved back :p
    I don't know the sizes, but i've also never heard of them being different.
    Frankly, i don't see the point. It's not like you're changing thsize of the slave cylinder.
    a larger master will allow more fluid per push, thus, making the stroke of the clutch less than it shoudl be... all the way down would be a floating point in the air on the pedal.
