What size tires on 15x7 rims?
D See 2
Whats the widest tire you can use on a 15x7 rim with 40mm offset? They will be going on a 95 GSR with omnipower suspension. I don't want them to rub anywhere but I'd like the widest tire possible. I'm guessing 215/60-15's will fit just fine? Or will I be able to run 225/60-15's?
215/60's are huge sloppy messes like 44DD tits...
205/50 is standard oversize.
+40 is not a good offset to go much wider that 205...
205/50 or 215/50 (if you can find it). The other sizes you listed are WAY too tall for the GSR.
Originally posted by E_SolSi@Sep 19 2005, 11:29 PM
:werd:
you will have the handling of a mid 90s taurus
[post=556927]Quoted post[/post]​
Nah, maybe a late 90s jellybean Taurus. Those were a little better. Shitty, but still better than the Taurus Robocop drove.
:lmao:
Those tire sizes you listed would slow you down because they would make your final gearing a bit taller, plus the larger diameter would rub in your fender-wells.
I run 205/50's on my 7" wheels and they are fabulous. 215/50 is going to be taller, so your acceleration will take a small hit.
