What size upgraded Fuel Pump for 200+ HP ??
mdixonjam
Member
I was wondering what size fuel pump to use for an LS/VTEC setup that should soon be capable of 200+ HP ??
Is the 190 LPH adequate or should I get the 255 LPH from Wahlbro ??
Is bigger better in this case ???
Thanks
I would just get the walbro..they are always good and if you ever want to increase your hp you don't have to change it...make sure your fuel maps are changed for the increase fuel flow
Yeah, and the 190 is probably gonna be fine. The 255 is better. it's up to you, what can you afford? You sure as hell don't NEED it.
Originally posted by nismogod@Jul 24 2005, 09:49 PM
a 255 is less then 100 bucks isn't it?
[post=530549]Quoted post[/post]​
Usally the 190 is $79 and the 250hp is $99.. For the $20 more get the higher volume pump..
