what sounds good
Discussion in 'Integra' started by boost_me, Jan 20, 2008.
  1. boost_me
    boost_me honda4life
    pinehurst nc
    Resently got a new job at a exaust shop and i have had a really loud exaust system on my car since i bought it and its about to drive me crazy... it has the stock maniflod no cat no resanitor just straight pipe to the muffler which is a cheep ebay one... can any one tell me what i need to do to get it sounding better the car is an integra b18a1 any help would be good because all the guys i work with have no idea they are all mussle heads
  2. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    get a cat... and a silencer...
  3. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    if you still want a little sound, try just putting a catalytic converter on first. it will smooth out the tone and make it about 1/3 quieter.
  4. drbelanger73
    drbelanger73 Beer is good for you.
    Bath, ME
    I know what you mean...
    I got my Scion with this cheap axel back bit on it. When i get up to around 75 it sounds like i'm flying a damn B24 down the highway. I'll get around to replacing it one day when the Integra is finished...
  5. boost_me
    boost_me honda4life
    pinehurst nc
    well when i bought the car it had a cat on it but it cloged so i just put a test pipe on it but the sound is the same as when the cat was on and i have the silincer on it now is their a brand of muffler that sounds good on that engine
  6. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    RSR or Invidia, the Apexi N1 is ridiculously loud.
  7. charleskwinter
    charleskwinter ignore
    idaho
    think of a trumpet or a trombone.... these 4" tips that end up sticking out of the back of too many cars actually add the worst of any exhaust sound, imo. they actually amplify the sound much like a gay cheerleader screaming through a cone. i am not sure if this is the case with your car, but high flow cat followed closely by a resonator, ending in your choice of muffler and regular tip is ideal. the tip should be the same diameter as the rest of the exhaust (2.25-2.5), and if it is a dual outlet they should be somewhat smaller than 2.25.
    another thought... following the final muffler you could increase the diameter slightly to give a more hollow sound without a large increase in noise. for example, 2.25 cat back to muffler, 2.5 from muffler to exit. i have never tried this but in principle it sounds at least interesting.
  8. drbelanger73
    Bath, ME
    :laughbounce2:
    Now that is funny...
  9. BrutalB83
    Rochester Hills, MI
    Silencers are gay. What's the point of putting a bigger, freer-flowing exhaust on your car if you're just gonna stick a plug in the end of it???
    To the OP: I would try adding a resonator first. Magnaflow makes some decent ones that are straight though, so they won't impede your exhaust flow. Also, what type of muffler does it currently have? An oval-shaped muffler will generally sound better and less obnoxious than the round "N1" type that all the ricers are so fond of.
  10. 91integra91
    91integra91 1# shifter
    GTA/ONTARIO/CANADA
    get a 2" or 2.5 tip so it will not generate alot of sound
  11. jomarlin123
    jomarlin123 K-5eRiEs Is ThE 5HiT.....
    Bronx, N.Y
    just throw on a turbo mufler it will sound good ........
  12. boost_me
    boost_me honda4life
    pinehurst nc
    its 2.25 all the way to a round muffler with a 3 in diamater its a piece of shit i put the silince in it cause it was so loud i could hardly hear the radio... put it this way i could drive through a parking lot and rev it to around 6000 rpm and set off car alarms :confused: just to give you a clue of how loud this thing is... thanks for the info ill check around and see what i can find ^_^
  13. YBLEGAL
    NW Indiana
    lol that's how loud my DD is anyway :p i love it... cruising at 3.5k rpm will set off car alarms...
    to each his own
    i'm rockin 2.5 from collector, through no cat straight pipe, all the way back
  14. boost_me
    boost_me honda4life
    pinehurst nc
    i have the same set up i loved it at first but after a while i couldent stand it any more
  15. YBLEGAL
    NW Indiana
    yeah it really is to each his own. if you dont want to shell out big money to fix it, you can always go to your local mexican owned exhaust shop (like me lol) and get cheap one put on. tell them you want flanges welded on the ends and it's no biggie like some people were saying. then u can unbolt it if you wanted. i'd say 2" pipe with a high-flow cat and a nice looking but semi restrictive muffler. it would have a lil sound. that's basicly the exhaust set up my buddy's runnin on his '96 eclipse GST...
    it's hardly loud at all. on the highway, i cant even hear him over my mom's motor and road noise in her honda odyssey (stock ALL, of course). nice lil hum inside his cabin tho.
  16. BrutalB83
    Rochester Hills, MI
    Your buddy could probably get a nice power gain if he upped his piping size a bit. 2" seems awfully small for a turbo'd car.
    I'm telling you guys, the sound is all about the shape of the muffler and whether or not you've got a resonator or two. On my car I'm running 2.25" inch stainless from the cat converter back, with a 22" straight-through Magnaflow resonator in the stock resonator location, and a straight-through oval-shaped Magnaflow muffler, 2.25" in and out.
    It sounds perfect, got that slight performance growl to it, but never loud, raspy, or annoying. Plus, the fact that the resonator and the muffler are straight-through means they're gonna outflow a turbo-style, but still be quiet due to the fact that you've essentially got two mufflers in there (the resonator and the actual muffler).
  17. YBLEGAL
    NW Indiana
    yeah, he really wanted to go 3", but it actually wouldnt fit around his rear suspension... and the exhaust shop was out of 2.5 and 2.25. AND my friend is impatient. that car's probably not going to last him long....but that's a different subject..
  18. BrutalB83
    Rochester Hills, MI
    Yeah I don't understand when people are like that with their cars. Why spend any money at all for cheap alternatives to the parts you really want? 99% of the time you just end up spending more money to replace them with what you should have bought in the first place.
    Oh well...it's his car...
  19. boost_me
    boost_me honda4life
    pinehurst nc
    ahhh im going to tomorow im puting a turbo muffler on and hopefully it will tone it down and depin it out ill let yall know how it sounds tomorow
  20. integra_ls_95
    integra_ls_95 New Member
    put a cat back on, i wond run my honda/acura without one i hate the sound
