What The Is It?
Discussion in 'HYBRID -> EG-EK / DC' started by Godspeed91, Apr 7, 2003.
  1. Godspeed91
    Godspeed91 Junior Member
    I put a 94 b18b into a 91 teg. used obd0 injectors, dist and harness and ecu. Car Cranks and idels at 7000 rpms. Throttle is closed. no vaccum leacks. Ecu shows 9 flashes. Checked crank angle sensor and is ok. Please help me out. :worthy:
  2. saturn_boy96
    saturn_boy96 88 C1V1C 53D4N DR1V3R
    Sheridan, WY
    are you saying your motor is redlining at idle?
  3. brian11to1
    brian11to1 Senior Member
    switch it to the OBD of the engine see what happens!
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    What will happen is it won't plug in.Check the throttle cable,remove it and start it up,if it is too short that would happen.I've never heard of an IDLE that high.
