bunkrd you
I'm planning on picking up a b16a2 with tranny that was pulled from a 00 and put it into my 00 civic coupe dx. Currently I have the 1.6l and was wondering where to start so far I was think a stage 2 clutch with lightened flywheel, turbo kit and run 8psi. Im pretty set on those two but only have enough in budget to either run new pistons and rods, or a new crank shaft and cam gears. Realistically if I decided to build the motor with the clutch, turbo at 8 psi, cam gears, crank shaft, pistons and rods where would that put me for estimated hp. Also if I did do pistons and rods would the other internals be okay with running a slightly higher compression ratio? Basically all in all I would like so guidence before I start building the motor. My goal is to around 250-280 hp if that helps any. If that is completely out of the question feel free to redirect me as needed. Thanks in advanced.
