What to rebuild my b18b
Discussion in 'General Tech and Maintenance' started by projectxspeed, Feb 20, 2005.
  1. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    I am looking for list for my b18b kinda like the one that crxb16 posted. I would like to include internals as well as bolt ons. Thanks guys
  2. brian11to1
    brian11to1 Senior Member
    Goals... budget?
  3. 92civicb18b1
    92civicb18b1 The Trisexual
    250-275 Turbo
    Get the LS pistons coated
    Scat Rods
    Sleeve it...if you got the money
    Crower Valvtrain (you could use another brand, but crower is known to be good)
    PnP is a must if your looking for more than 300hp
    If you sleeve it, keep the Ls pistons, scat rods and PnP you'll be good for at least 400 hp.
  4. SlushboxTeggy
    NJ to MA to CA
    now that i abondoned the ls-vtec build im interested in an ls turbo. would you use the crower turbo cams or the ls cams?
  5. 92civicb18b1
    If I had the extra money I would get the crower, but I'm on a budget so I'm sticking with the LS cams.
  6. projectxspeed
    New Hampshire
    I feel like such a n00b. :kick: I want to do a rebuild of my LS engine both bolt ons and internal work, BUT I want to keep all parts OEM.
    Budget = Whatever it costs (within reason aka I can justify an OEM rebuild but not aftermarket)
  7. 92civicb18b1
    go with aftermarket rods, its worth it.
    Get some pistons (OEM are fine) to have CR at 9.5:1 or CR of your choice if your keeping turbo
  8. projectxspeed
    New Hampshire
    I am rebuilding my engine for my turbo but I wanna keep cost down so aftermarket rods are out. I am going to re-use my block, pistons, rods, crank, head, valves, springs, cams.
  9. 92civicb18b1
    so you're replacing seals and rings?
  10. projectxspeed
    New Hampshire
    right I was thinking about doing rod bolts too, any thoughts?
  11. projectxspeed
    New Hampshire
    any other suggestion for OEM replacement parts?
  12. projectxspeed
    New Hampshire
    Here is my compiled list for my rebuild
    OEM Water Pump
    OEM Timing Belt
    OEM Fuel Filter
    Adjustable Cam gears
    OEM Piston Rings
    OEM Head Gasket
    ARP Rod Bolts
    ARP Head Studs
    Stage 2/3 Clutch+flywheel
  13. 92civicb18b1
    I suggest an Exedy Clutch, whatever stage you feel necassary. They are great clutches for a very good price.
    An Ebay Flywheel. I should have taken a picture of mine, it is excellent quality. I was going to resell it if I didn't like it but it really is a great quality peice. I don't care what people say, ebay or not. The shit is worth every penny.
  14. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    CTR pistons they will go right in and they will raise your CR.
  15. 92civicb18b1
    I think he's going turbo, so that may not be the route he wants to take.
    And don't you have to shave the rods or something to make them fit?
  16. integraslut78
    KiLLa kALi
    Oh sorry if you are going turbo do not go with the CTR pistons.
    Yeah they take a little coaxing to go in but they work.
  17. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    since your staying oem how about a b16 intake manifold?
  18. projectxspeed
    New Hampshire
    Will a b16 manifold bolt up to my b18b head?
