what to use for trans fluid?
Discussion in 'General Tech and Maintenance' started by VTECPOWER, Nov 21, 2004.
  1. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    what kind of oil do i use for a manual trans in a 00 civic Si w/ the b16a2?
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Honda MTF.
  3. VTECPOWER
    Winchester, VA
    honda mtf aka 5w30 or 10w30?
  4. swanny
    swanny Senior Member
    buck teeth and government checks, PA
  5. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    GM Synrchomesh Friction Modified rocks my transmission!
  6. beerbongskickass
    beerbongskickass Senior Member
    Longview WA
    I use regular Castrol GTX 10w30 in my engine and transmission.
  7. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    not such a good idea scince oil comes with detergent biult into it and does not have the additives that come in gear oil
  8. beerbongskickass
    Longview WA
    I do recommend Honda MTF over anything else, but if you don't have that, 10w30 would work perfectly fine. I would put regular engine oil in my tranny before I put gear oil in it. All that said, I don't think it's that big of a difference as long as you change it often.
  9. 94RedSiGal
    94RedSiGal Senior Member
    Massachusetts
    Honda MTF. Although my Si and GS-R now both have one quart of GM Synchromesh in their trannies with the balance being Honda MTF.
  10. Citizen_Insane
    Minneapolis
    MTF unless you have an aftermarket LSD, Like a KAAZ or Quaffle, then you NEED Synchromesh. That stuff is the SHIT! It made my tranny run silky smooth...until it all ran out on the pavement from my cracked tranny casing :(
  11. hcivic.com
    i run gear oil in all my trannys.
  12. beerbongskickass
    Longview WA
    I have a Quaife LSD and you don't NEED to run that syncromesh stuff. Whatever Honda recommends will be fine, and that is Honda MTF or 10w30 motor oil. You can pretty much use whatever you want, but I personally wouldn't want to run syncromesh or gear oil.
  13. Citizen_Insane
    Minneapolis
    Um...it says in the manual to only use motor oil as a temporary and to imidiatly replace with MTF. Ok, you don't have to, but I love it.
