What Tranny Should I Get?
Boosted CRX
First post...I need to know what tranny to get or which would work out the best and how much I would be out installing one...And also ecu..
b16 and gsr head w/port and polish
eagle rods
je pistons 9.1:8
hondata hg
arp studs
itr manifold
crower springs and retainers w/stock gsr valves
550cc injectors w/modified d16 fuel rail
255lph fuel pump
d16 modified b&m fpr
T3 .63/57 c wheel
Custom manifold/dp/dumppipe/piping
Shelby dayton FMIC
1G DSM Bov
Audi wastegate
oil lines
Greddy Profec EBC
AutoMeter tach
MSD Dis-Tach Driver
MSD 6BTM
bst/a.f/egt w/probe/water/oil gauges
bosch 5wire wideband
Still working on piggy-back..either greddy e-manage or cybernation "blk magic"l&f
rear neuspeed sway bar
h&r coilovers
ebc pads w/generic rotors
stock exhaust and later on an obx catback
toyo tires 215/35/17
Helium 17" rims
ngk plugs and wires
91 oct gas
Maybe a phantom LSD when I find the right tranny
ACT 6 puck or a CM 4 Stg
Why are u going with a gsr head with a b16 bottom end, do have it just laying around? But if your going NA I say stick with the b16 trany.
Must have scaned over the part you said you were going turbo :bash: Id go with an ls tranny with a turbo
9.1:8 and NA :p j.p
Yeah, I was told gsr and ls in H-T.Ls have shorter gears?
So this might be the tranny maybe..
Oh and btw..Im going to try to shoot for 260 daily driven w/(6-8) low psi...
Ive seen a stock b18 w/ t3 60-1 hit these numbers @8psi so I think its possible..
